Hi CodeMonkey !! Many thanks for suggestions but none of them seem to be using the java.util.timer. I am convinced that is what I need to use together with Timertask. What I really need is an example of incorporating them into an Android Activity.
Once again CodeMonkey for all the trouble you have taken to find these possible sources.
I think the last one seems the most promising as it contains the two features which I think will do what I want. What I need is a one shot timer in which I can set any delay that I need which will trigger a routine at the end of the delay. The project will not be executing any code during the delay.
