How to use my wifi modem on mu android device
I have Samsung Galaxy SL i9003. My BSNL Broadband WiFi modem WA3002G4 ain't getting connected to my android phone. I wanna use my bsnl wifi modem for downloading applications and games large in size....what to do ? Plzzzzz help!!
You will need to have your phone search for an available wifi network. Once it finds your wifi modem you will need to enter they key to gain access and if your network is open you should connect and be good to go. If you are having problems beyond this you might want to check into your phone's area of discussion to see if you need do something that I'm unaware of. Here is a link to that area: Samsung Galaxy SL - Android Forums Good luck and thanks for using these forums.
Thanks for the reply... The problem is that my phone shows my WiFi modem in available Wifi Networks and the signal strength is strong, too...but still it can't connect. My Wifi modem is an open network...while connecting, it shows "obtaining IP address...." and then "connecting..." and then "disconnected" without being connected ! :O plzzz help... I couldn't find my problem discussed in my phone's area of discussion whose link you provided to me. :-/ Thanks
I'm no wifi wizard. I've just gone through the gyrations mentioned above and bingo. You might try looking in here: Android Lounge - Android Forums
Once you are in that area, use the tab to "Search This Forum" for wifi connect or something similar. You should end up with many pages of messages left by people looking for the answer to connect to their wifi. If you can't find a similar problem just ask. There are many users here with a great insight to wifi. The only test I would have you try beyond seeking help is to attempt to connect your phone to another wifi and make certain it's not a problem with your phone. You should find an open network in many public places.. most McDonalds even lol.. Starbucks etc. I wish I knew more.. I'd certainly come to your aid. Best of luck.
