Root how to use swapper2
hemanth
Member
hi guys
i have 3 partition in my sd card
1st
primary fat32
2nd
primary ext2
3rd
swap
now how to configure swapper2 to use the swap partition
we have to enter the location of the swap in settings
is this the right one for my current partition
/dev/block/mmcblk0p3
and also how to find which ext version is supported by my phone?
hey i did not make any partitions in my card,
adjusted swapper2 for 512 of memory
then wait till it makes a swap file
chk swap memory by using info from setcpu app
This is correct location for your swap file.
Now how to configure it,
1. Open Swapper2
2. Go to Settings
3. Go to Advanced Preferences
4. Tick use swap partition
5. Untick Recreate swap file and Reformat swap (if already unticked then ignore it)
6. Back
7. Tick run swapper at startup
8. Set swappiness amount to "60 (system default")
9. Now back to main screen
10. Click ON
11. Once done directly press HOME button i.e. don't close it
Enjoy :)
