Phone: Samsung Prevail
ROM: CTMod 3.80
Kernel: KoumaKernel 2.5
CPU gov: smartassV2
i/o sched: sio
read-ahead cache: 1024
min/max: 200/825
Hi all, the Samsung Prevail was my first smartphone about a year ago. Then about two months ago I decided to root it. It has been fairly unstable since. It simply won't stay on for long periods, or will shut down / freeze at random times.
I found that adding System Tuner and putting the recommended settings on tweaks on SysCtl to add some stability. Any way to use these settings to just try to keep the phone on longer? AKA sacrifice speed and responsiveness to just... keeping the phone on.
I installed the Koumamod and partitioned the SD Card to act as hard drive space (and bought a new SD 10 card). I've also tried out a bunch of settings, but have landed on smartassV2 and sio with a read cache of 1024. (Edit: Usually running min 200mhz and max 844mhz.) If anyone has any tips on the dozens of settings I have here and what might work better for keeping the phone on... it'd be appreciated.
To be clear: if I leave the phone charged overnight it will inevitably turn off. I thought it might be overheating so I charged it up to about 80 and left it turned on but unplugged and it still shut down (and rebooted in the morning to a battery of about 7). I don't think it's the battery. I routinely charged overnight when it was not rooted and it didn't turn off much before root.
In addition to that, the phone will just randomly turn off during the day. Sometimes it comes right back up, but about half the time I have to try rebooting several times, removing the battery, etc.
ROM: CTMod 3.80
CPU gov: smartassV2
i/o sched: sio
min/max: 200/825
