how to write SMS ?
dhongdhong
How to SMS ?
Here is a instruction of booking of Cooking Gas of a Company ...
Type on your Mobile
REG>space<DistributorSAPCode>space<ConsumerNumber
If my DistributorSAPCode = 123456 and ConsumerNumber = 342167
then What would be SMS content ?
Is it
REG> 123456 342167
OR
REG 123456 342167
OR
what ?
which is the correct format ?
The normal convention is that text within angle brackets represent variable data (e.g., <your name>), and text within square brackets represent optional data (e.g., [member ID]). Either way, it is intended for you to enter the information without the brackets. It appears that your instructions are missing a couple of angle brackets (or have a couple of extras).
