Root How To??
BigBeefy
How do you free up internal phone memory? When I click on my Quick Settings app, I see that I only have 15% (23mb) of free Phone memory. Is this normal?
Maybe this is why my phone is a little laggy at times?
Can anyone shed some light on this for me?
I too am running Aloysius v12 and have laggy times. The dev has stated that the high memory usage is more than likely from the graphics. I am using Apps2SD with this and I have 22MB free.
I am not using Apps2SD. I havent read enough about that to know if it will do me anygood or not. I dont have many apps to begin with. I wonder if this rom is full of bloat tho? I dont use sense at all, but I love all the color that this rom has.
I'm sure you can find a theme that is just like the one that aloysius uses. Not the same thing, but same colors and such. I used that ROM for a bit and had no problems with it.
Apps2SD is the main reason I rooted. I hated being skimpy with the amount of apps I downloaded... I installed a few things internally in case there is some speed difference compared to apps installed on the Apps2SD partition, but all of my games and misc utilities are installed there. I have 116mb free on my internal storage area, and 385mb free out of the 512mb partition for apps2SD.
Other than a little lag here and there, no real problems with it.
What ROM are you using now?
