I just bought my inspire 3 days ago and so I'm loving it. Is there some to down load a how to book for the features? I haven't been able to figure out how to add pictures to contacts. Also is there anyway to get audio books off of itunes and put on the phone?
If the contacts are save to your sim card then you must copy them to your phone first. While in the contact list tap menu-import/export-import from sim. After this you will see duplicate contacts tap menu-view-uncheck the sim box.
Now you can go back to your list tap a contact then menu-edit then tap the picture box at the top left.
If you have iTunes set up with default store locations you can just copy the files from <user account>/Music\iTunes\iTunes Music\Audiobooks assuming they are in m4a format and do not contain DRM.
