How To
RickyChin
Hi all,
A few 'How To' questions here....
1) How to add new apps or apps shortcut on the lock screen ?
2) How to get the 'Smart Connect' window to appear ?
I'm having a Z2 running on ver 4.4.2 with accessories like Smart Band SWR10, SBH50 and Smart Tags....anyone know any good apps for these ?
Also am interested in finding/getting auto wallpaper changer for the lock screen.
Thanks
Welcome to Android Forums, Ricky. :)
I've only been able to add widgets. On an empty screen tap the + and a widget list will open. Select the one you want and it will add itself to that screen.
It doesn't, unless you actually open the app itself from the drawer. Ordinarily Smart Connect runs in the background managing things unseen, only showing an optional notification when events start/end.
The essential app for the SmartBand is Lifelog, and I expect more apps to appear that leverage its functionality once devs get to grips with the SDK.
I have an SBH20 and modified the supplied "Music on the go" Smart Connect profile to use it.
Smart Tags I've yet to find a regular use for.
