chirantha7777
1. Download Orbot from Play Store.
2. Start Orbot and turn it on
3. Settings -> More -> Mobile Networks -> Access Point Names -> Select to edit your access point.
4. Change Proxy to 127.0.0.1
5. Change Port to 8118
6. Save changes and launch your Apps or browers.. all data will be securely encrypted through the Tor network!
7. Don't watch too many illegal sites or fill up the phone with videos ok?
TO SET UP FOR WIFI
1. Settings -> WIFI and turn it on. Make sure you are connected to your access point.
2. Settings -> WIFI.. Press and hold your connected network. In the Popup select "Modify network config"
3. Check the box "Show Advanced Options" and scroll down set Proxy setting to "Manual"
4. Proxy Host name "127.0.0.1" and port 8118.
5. Save changes! Your WIFI traffic will be routed through the secure Tor network.
TO SET UP FOR WIFI
