huh? not sure what you mean.
I believe the app designer intended that in order to help people find stuff for their devices faster..
It isn't information that an app need 'permission' to access. Or put another way, any app that has zero permissions would still be able to determine what device you are using. I'm not a developer, but if I were to make an educated guess, any app would need to know things about your device (screen size, memory, device make and model, processor, etc.) in order to be compatible with all the variants that exist. Nothing nefarious.
i'm not sure why this is a concern. i can tell you that this is the best forum on the internet and i have never had any issue with security or privacy. the only permission that i see within my phone's settings was access to my sd card which you can toggle on or off.
For information, depending what browser you're using, every website that you browse may know what device you have, like the make, model, and Android version it's running.
OK, so I can't answer that question, but I moved this to the App Dev section where other developers may be able to fill in the gaps.Thanks for the hypothesis! I suppose i am more curious than worried about how this is done and what if anything could be changed about it, with any app for that matter.
Very true! My curiousity was on the how this is done. And maybe why also. I noticed in the privacy policy on the website that it seems to be rrlated to their clause regarding log files.
I will personally ask admin and see if we can get the app developer's input. I mostly use my browser on both PC and phoneThis makes sense, but at no point was this permission discussed during the sign up process nor does there seem to be a way to disable it, and im a bit unclear what permission that would be. Im assuming maybe this is included in their ToS / privacy policy. Though i didnt see that either during sign up, maybe i missed it. Anyone know where to find that?
Contrary to all the gibberish replies above, we know everything about you now.....everything.
In fact, put down that delicious looking sub sandwich you are eating, and leave, just leave everything behind![]()
By the way, welcome to the forums![]()
For web browsers, the device's make and model can be in the User Agent String, that any website may see and log.
For example 'Mozilla/5.0 (Linux; Android 9; ALP-AL00 Build/HUAWEIALP-AL00) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Mobile Safari/537.36'
