HTC Amaze 4g help
mom2bells
Hi there,
I've had my amaze for several months now, and I love it.. right now i'm a little (actually quite) sad.. the bottom four options (home, settings, back and search) aren't responding. I don't want to go to tmobile to figure this out.. I'm hoping there might be an easy solution? Does anyone have one?
Thank You,
mom2bells:(
Welcome to the forums mom2bells!
Glad to have you here, sorry to hear about the issues with your device though :(
I would suggest trying to perform a hard battery reset by removing the battery, reinserting and restarting the device.
If this doesn't work try a factory reset...if you do not want all your data wiped try going to T-Mobile.
Hope this helps and thanks for joining :D
Hi there,
Thank You,
mom2bells:(
Seriously, I would strongly suggest you take the phone in for repairs or a replacement. Problems like this one only gets worst.
As suggested in the above post, performing a reset might fix the problem.
By the way, welcome aboard. :)
