HTC/Android Bluetooth issues
Adiadiere
I'm not sure if its just the HTC Sensation but I've noticed that the Bluetooth music streaming, streams music in a very low bit rate. Making it muffled and unusable for most. I vote if its android that the problem is fixed soon :) but if I'm being stupid then I appologise :o But whatever the problem, it needs to be sorted! sharpish!!
Hello and welcome aboard. It could be one of two things → You may have a defective Bluetooth or It's just how your device plays / streams music.
You can stop by your device's support forum to see if this type of problem has been mentioned before. Here is a link to that area: http://androidforums.com/htc-sensation/.
Best of luck. :)
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
