HTC Battery Widget
ral
Android Expert
I downloaded a nice battery widget from HTC. It is a 1x1 animated widget showing percentage of battery life. When you click it, it pops of this window with more interesting information:
I wanted to ask if this application uses a lot of battery life. No point monitoring my battery if I use more of it.
TIA
I got it from the HTC Hub, which I accessed from the shortcut on a HTC Desire HD.
You can access it through your widget settings on your HTC Desire HD.. like me :) Battery life is totally unaffected by it.. I like knowing how much juice I'm using each day. I'm noticing a 3% per hour battery drain with all my widgets running and updating.
@Vicdude
There will be a new official Gingerbead ROM for your "obsolete" HYC Desire. Am pretty sure that you will get the newer Sense UI too... hhhmmm, anyway I can extract the file and send it to you (without rooting)?
