Help Htc Chacha Keeps Turning off without Power Cable !!
Hi,
I'm facing this problem on my HTC chacha A810e.
My phone keeps turn off without power cable , i've double check my battery but its fine , already done with hard reset and data reset but no luck :(
but when i plugin my htc with power cable it starts working.
Any help please :confused:
Plug in the charging cable. Turn off the phone. Leave it charging AT LEAST 24 hours. Then see if it runs without the cable.
If not, either the battery isn't "fine" (I don't know what tests you ran to determine that it is, but measuring the voltage at the terminals has nothing to do with whether the battery is fine or not) or it's not being conntected to the phone (bad contact, broken land on the PC board).
