Help HTC Desire 400 problem
CenturionB
Hi ,
I have HTC desire 400 too, android 4.1.1
My phone worked fine , then fell down and started having problems . When you open the phone started perezagruzhatsya browser , and even when performing random actions . Reset partly helped , the browser opens , but the phone has become all the same to fail , what you can do tell ....
"fell down", you dropped it? The impact could have caused damage, if so it would likely require professional repair.
Yes, I dropped it, I know, that may be something to try for yourself ? and if it does not include a specialist?
Could be something like the main logic board is damaged. How competent are you at disassembling and reassembling it?
Checkout ifixit.com should be some useful info there
Thank you for your advice, I also think that the hardware , but hoped not. Well, who else can tell something interesting ?
