HTC Explorer - Internal Memory Low - MessageCS, PhoneStorage
Hi,
I have got HTC Explorer in October, 2011.
Since then I am facing an issue with Internal Memory Storage Low.
I am used to uninstall all the unused applications, use to clear the cache, etc such that there can be free at least 10-15 MB memory to allow the existing applications to function properly.
One application MessageCS is taking quite more space in the memory and I am not able to delete it. Same way Phone Storage is the similar one taking lottt many space but I am not able to clear it. And both keeps on growing like anything.
It's worth noting that I dont have more than 50 messages in my mobile! not more than 20 mails, no mms!
Can there be any means by which I can clear the data/junk/logs/temp etc for this two applicaitons?
Please dont suggest me to reset the phone, I already know it, which so easily makes me engaged for few more days in installing the applications once again and stuff like that..
Please suggest some appliations or some way to get these cleared..
Can I anyhow increase internal memory space of my phone?
Thanks and Regards,
Nirav Khandhedia
Welcome to Android Forums, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device( Android Phones - Android Forums ) and your Carrier ( Android Carriers - Android Forums ).
For Tablets check this section out, ( Android Tablets & MIDs - Android Forums )
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
To get the proper support for that device, I would post in your device section, you will get the proper advice needed, HTC Explorer
Welcome aboard. Hopefully this place will be of great help to you. <(@ ̄︶ ̄@)>
