Help HTC flyer Honeycomb, pen working with Sketchbook pro?
scaliero
Hello
I am new here, so happy new year to you guys!!!:rolleyes:
I have one question: The htc flyer pen could not work with other application softwares when the tablet was with gingerbread, the pen only worked with HTC scribe and note.
Now that the update is available for honeycomb, does anybody know if the pen will work with others softwares, for example, autodesk sketchbook pro???
I draw and might get this tablet if the pen works. :o
I hope you can help me!!!!
I'll install the free version: Autodesk SketchBook Mobile Express this evening and see if it works with the Pen and report back. I'm assuming that if it works with one it should work with the Pro version.
From the reviews for the Pro version:
"Alan on January 6, 2012 (HTC Flyer with version 2.0)
Good, but could be great.
Pros: - Works with pressure sensitive n-trig styluses on the flyer, thinkpad, xyboard etc. - uncluttered interface - drawing engine works great, smoother lines than even photoshop on the desktop Cons: - Needs palm rejection and/or ability to turn off touch input. - can't make bigger canvases - dropbox login settings not saved."
helloI got the htc flyer, updated it to honeycomb and voila: sketchbook pro does work with the htc stylus!!! whicked!!!!! :)
