Some time ago i installed all the things on my HD2 in order to install the android OS. I installed the radio, the HSPL, the aMagldr..... Everything was fine, i was always changing between android and windows, depending on my mood until one day i had to replace the Lcd screen, i did it myself, no problem... I had an android rom installed when i replaced the screen and since then i can't access the HSPL screen, That colorful screen that you access by pressing volume down + power button...
so, that is my problem, i am stuck with android (Only old versions like 2.2) because i can't go back to windows without accessing that colorful screen because it is needed to sync.
I already bought a new volume flex, tried the red button near the battery... I just can't access that screen anymore.
I would appreciate very much some help
best regards
best regards
