Hi,
I have an HTC m8 with latest update: 5.0 (lolipop).
Suddenly the default earphones started not to work. It worked perfectly before, i didnt install any new application or update. I restarted phone. I reset it to factory defaults but still same issue.
If i try the earphones to another device, they work. Also if i try another earphones on my device they work. Only default(own) earphones are not working on its device(htc m8). When i insert the jack, earphone icon is shown to the status bar for 2 seconds and its gone.
Has any one faced same issue?
Thanx in advance.
Thanx in advance.
