Help HTC m8 wifi problem
After flashing rom to stock and running the os for a while i discovered problems with my wifi , it disconnects a lot and I have to restart the phone every once in a while to get it back again.
any solution for this problem ?
yes my friend and also in the stock rom , im now on stock rom the one you gave me its link
and the baseband version is 1.21.21331147A1.19_2G_20.63.4196.01L_F
I've looked over the main Viper thread - a few people are complaining about this as well - usually solved by having the right firmware - but you already have that.
You can dirty flash the rom - just install again and do NOT choose to wipe anything. See if that fixes it.
One guy had it and was using the AOSP lockscreen rather than Sense. No idea how that would matter but you could also try changing that.
