Root HTC Magic Problem - Cannot restore phone
koosbeer
Hi Everyone
I must apologize if this is a annoying beginner question but I have a problem with my HTC Magic.
I attempted to load the Fatality Hero ROM onto my HTC Magic phone. I already had the daldroid ROM running on it but wanted to try out the Hero ROM. I followed the procedure as described by individuals on the web (and I have done it before to get the daldroid ROM working). The phone was working fine with adb. I followed the following steps:
- I Selected
my phone got stuck today doing an upgrade of a rom... sucks i know
well maybe you can have better luck than me:
1.take you nadroid boot/system/data.img's and put them in the tools of the - SDK
2. get into fastboot USB
3. type fastboot devices (a serial should show up)
4. type fastboot flash boot boot.img <-i get stuck here
5. type fastboot flash system system.img
6. type fastboot flash data data.img
reboot and it should be good.
good luck... post back here if it works for you
You may not have a good Environmental Variable set to include the path of fastboot and the backup files ....
Following is a link to a guide I wrote for restoring Nandroid Backups....
within the guide is the code for batch files that perform the commands ...
Read these and see if they agree with your steps ....
How to Restore a Nandroid Backup - GetYourDroidOn
rem === Summary of command run to restore essential elements from the backup ==============
rem fastboot flash boot /SDK_15/NandroidImages/boot.img
rem fastboot flash system /SDK_15/NandroidImages/system.img
rem fastboot flash userdata /SDK_15/NandroidImages/data.img
rem fastboot flash recovery /SDK_15/NandroidImages/recovery.img
rem flashboot reboot
rem ==== End of FstBootNandroid.bat ==========================
i just used the instructions from this thread and my backup worked. at first it didnt because my spl was 1.33.009 so once i switched it to the 1.33.2005 engineering spl and then followed these instructions all was well
thanks
