Help Htc one x battery stats
I have noticed that when I power my phone off and then power it back on hours later it has clocked up all them hours in my stats. It is like the phone is not properly off . Anyone else noticed this. All my other phones have never clocked hours or used battery while turned off.
Do you have fastboot enabled? If yes (I think it is by default), the phone isn't actually off, it's just in a state of hibernation so it's still actually on. That could be why it's not reporting what you expect it would.
Problem solved mate and very much appreciated. One thing I have noticed now though is that the phone isn't remembering stats now and every time I turn phone back on the battery time is back to zero. The fastboot untick has solved the other problem though so happy days
These stats are over a period of starting at full charge, then left overnight (3G off etc etc) and not losing any % while not in use for approx 7 hours, full day at work with browsing, texting little gaming etc, so probably light use, then 3G etc off again at night to gain as much use as possible.
