Help HTC One X completely dead! Help1
Hi, I changed my seen phone was absolutely fine for 2 weeks then it's just died,m wont turn on or even connect to the PC, NO LIFE WHATSOEVER?
Anyone had a similar experience or have any ideas.
Tested the battery its showing 2.78v on a 3.7v battery not sure if that's relevant, still would have thought it would have booted up or at least installed the drivers to the pc, but nothing.
Thanks for any ideas in advance
Seaspray99:confused:
Have you tried plugging it in and leaving it plugged in to a wall outlet for a day? Or a while? I had this issue and plugging it into the wall for about a half hour gave me the flashing red light then the solid red light and I was able to turn it on.
