Help HTC One X problem- Lock Screen Icons.
A few days ago, I realized that the icons at the bottom of the lock screen, that can be dragged into the little circle, ie.) Camera disappeared for some reason. Is there anyway to get those icons back?
Hi
Try going into Settings > Personalize and make sure the Lock screen shortcuts option is checked.
Or else, also make sure that the 4 dock spaces at the bottom of your home screen are filled with shortcuts. If they're empty, no shortcuts will appear on the lock screen since the lock screen mirrors what the dock contains.
Hope this helps.
