HTC Sense & Launcher Pro
GeoM
Have had my HTC Sensation for a few months. Been using Launcher Pro for at least 2 months with no problem. Now today, the HTC Sense has hijacked the phone, and even though I use Home Switcher and have told it to default to Launcher Pro several times today, it won't seem to take hold. I've rebooted several times. Anyone know why this is happening?
Thanx,
George
If you go into applications and clear the defaults for Sense that should fix it. Or you can uninstall the launcher, reinstall it, and then when you press the home button it should allow you to choose between Sense and Launcher Pro.
atkjhi, that seemed to do the trick. wanted to give it a day to see if it would hold up, and it did. thanx so much for the help,
g
