If you feel like animations are too slow and apps don’t move as fast as you’d like, this simple trick can speed up the HTC U11 dramatically.
- Go to Settings > About > Software information > More
- Tap on Build number until a message says you are now a developer
- Go to Settings > Developer options > Advanced
- In the Animation section, tweak the scale for Window, Transition, and Animator duration. (We recommend .5x)
