Htc usb port is broken is there any way to root it without using the usb cable?
Which Model HTC do you have??
Welcome to Android Forums, we are happy that you joined, look around and enjoy. :hello: :congrats:
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
Here's the deal.. you may be able to use an app to root. I don't know. However, if you don't have the use of your port, you won't be able to restore in case you brick... bad news. I'd advise against it at this point.
Steven
