RazzleFnDazzle
Hey everyone. I recently just released a new FREE app called HTPC Remote.
https://play.google.com/store/apps/details?id=com.ras.htpcremote
For any of you 100k+ users who have used my previous app of Phone To Computer it is the same concept, but a much easier to setup and use.
As of right now it works on Linux, OSX, and Windows. It will allow you to use your Android device as a remote control. It will allow you to launch your media on your computer from your device. It contains media keys for a few different media players.
Media players currently supported:
VLC
Windows Media Player
iTunes
YouTube
Hulu
XBMC
The way it works:
Your device will send keyboard commands to your computer and execute them. If a media player has keyboard shortcuts the app will be able to support it.
You will need to install some software on your computer for your application to communicate with it. The software is available from http://sites.google.com/site/razhtpc
Future releases planned:
Add the ability for users to create a remote for any media player they desire as long as it uses keyboard shortcuts
Search and Launch (on your computer) Hulu/Netflix movies/tv shows directly from the app.
Please take a look at tell me what you think of the app or any improvements you would suggest I look into. Thank you.
VLC
iTunes
YouTube
Hulu
XBMC
The way it works:
