I'm very new to android programming. I'm more used to c# programming.
I'm having problem sending POST data to a PHP page using HttpURLConnection.
i know that POST data has to be encoded in ascii and sent to the server in bytes format. this is what i did, and i have been unsuccessful. I tried following several web instruction to no avail.
URL url;
HttpURLConnection conn;
loginurl=new URL("https://mysite.com/test.php");
conn=(HttpURLConnection)loginUrl.openConnection();
conn.setRequestMethod("POST");
String charset = "UTF-8";
String qry =URLEncoder.encode("param1=1¶m2=2",charset);
conn.setRequestProperty("Accept-Charset", charset);
conn.setRequestProperty("Content-Type", "application/x-ww-form-urlencoded");
conn.setRequestProperty("Content-Length", ""+Integer.toString(qry.getBytes().length));
conn.setUseCaches(false);
conn.setDoInput(true);
conn.setDoOutput(true);
//sendrequest
DataOutputStream out= new DataOutputStream(conn.getOutputStream());
txtResponse.setText(out.toString());
out.writeBytes(qry);
out.flush();
out.close();
in my PHP code, all i'm doing is spitting out the value of param1 and param 2. they all turned out empty.
i tried modifying the parameter so that it will encode only the values, but not the key. however i still can't make it to work.
i tried out.write(qry.getBytes);
also tried out.write(("param1=1¶m2=2").getBytes));
nothing works!
what am i doing wrong????
URL url;
//sendrequest
out.flush();
out.close();
nothing works!
