Help Huawei ascen g 300 factory reset Failure & signature verification failures
StaatuS
Helli all,
I had rooted my Huawei Ascend G 300, and installed Some uninstallation software.
Afther that I began deleting software and Apps I started (bit paranoid) deleting Some kernel applications that were essential tor booting my device .
What I discovered achter THE next reboot.
So I decided to erase data and factory Restore my Android but There I was facing THE next problems...
Afther wiping/factory reset iTS ...
It's formatting without problems but when I select reboot system now iT keeps hanging on THE huawei boot logo
So I downloaded Some firmware and kernel software and tried THE Touchscreen firmware update and also THE Apple update from sdcard afther selecting THE downloaded files it is saying ....
Finding update package.....
Opening update package....
Vergifying update package...
But then it's going wrong;
Signature verification failed
Update fail and delete temp. files
Formatting /cache...
Installation aborted
