Huawei Ascend 2 {HELP!}
Okay so i have the Huawei Ascend 2 for Cricket and I've been having a couple of issues. So everytime i go to the android market or youtube it doesn't work ... the only time it works is when I'm connected to wifi but when there is no wifi and my data is on it doesn't want to work... Could there be a solution to my problem ? Please Help :(
Sounds like wherever you got your phone didn't put you on the ANDROID PLAN.
It doesn't happen often,but,there are some here that it has happened to.
Try going back to the point of purchase & have them verify that you are on the right plan.
