Huawei Ascend Plus H881C
  • Start date Start date
A
Android Question
Guest
Does this cell phone have a Sim card, if so, where is it located?
No the Huawei Ascend H881C from Straight talk or t mobile is a CDMA phone and therefore doesnt have a sim it uses what is termed over the air programming. Use SRS one click root to root it easy just follow directions it installs on your comouter then you plug the phone up then you can get a sd card 16 gig ultra is what I recomend look up partitioning for link 2 sd and remember togo into the settings once you get your sd and set it to download to storage under the storage item. I enjoy it
