Huawei Ascend Vs LG Optimus M (Both Ver. 2.3)
What would your choice be?
  • Ascend
    Votes: 1 16.7%
  • Optimus
    Votes: 5 83.3%
  • Total voters
    6
Follow this thread for LG users opinion if you guys need to : http://androidforums.com/lg-optimus-m/348243-lg-optimus-m-vs-ascend.html#post2775527
(this is probably the wrong thread to post this, but I wanted to know your opinion as a ascend user)
ok, I was going to get ascend because I like the layout and screen then after some research - I found out that LG Optimus M is BETTER? Why? Because its 2.2 and huawei is 2.1 -_- so I'm like wtf? that's not even a good way to differentiate both because both can be rooted and flashed to 2.3 (ginger)
So, I am a statistic guy, spec guy, I do not buy just because it looks good or just because its cheap or expensive. I only pick what's worth getting
So with that said, what would a good choice be? Pros and Cons
It's Huawei ascend 2.3 vs LG optimus M 2.3 both rooted, both can be customized, flashed to CM7, overlocked , w/e - you guys can argue what to do in order for ascend to win or maybe LG to win or even include the price (49$ for ascend 99$ for lg)
I only have 6 days and 23 hours to return this phone if ascend wins - if LG wins, then so be it and I will keep this phone
the LG Optimus is much better than the ascend if I was you I'll jump the ship without thinking twice (also LG will upgrade th optimus to 2.3 as for the ascend 2.2 is it)
