Define "low". How old is the battery? How far down do you let it drain before charging it? What's using most of your battery. (From Battery in Settings?) How long does it go between charges? How many hours do you spend actually using it (screen on, running an app or making calls or texting)? Fir sine phnes 12 hours is a long time. For some, 24 hours is short life.
