s7yler
Full Comprehensive Review
Full Unboxing & Hands-on video of the Huawei Honor 7 (PLK-UL00)
AnTuTu Showdown/comparison - Honor 7 vs. OP2 vs. LeTV S1
Camera samples here:
http://www.mediafire.com/folder/ecvhwbya1xo1m/Huawei_Honor_7_Camera_Samples
If you have any questions to the phone, feel free to ask! I am currently using the Huawei Honor 7 as my daily driver and I love the phone so far. Even using it more than my OP2. As I like the Honor 7's 5.2 inch better than 5.5. For me a much better phone size and very pocket friendly.
Specifications:
- Huawei Honor 7 (PLK-UL00)
- 5.2 inch, FullHD, JDI LCD / IPS 1920x1080 pixels, 423 PPI
- Fingerprint ID scanner
- Hisilicon Kirin 935 Octa Core 2.2Ghz/1.5Ghz
- Mali T624 MP4
- 3 GB RAM + 16 GB ROM
- 20 MP main camera + 8 MP front camera
- 3100mAh battery
- Dual Nano SIM / microSD card support
- EMUI 3.1 OS (based on Android 5.0)
- Multilanguage & with Google Play Store
- Supports 2G & 3G & 4G LTE network
- Network: GSM 850/900/1800/1900 MHz, WCDMA 850/900/1900/2100 MHz, FDD-LTE B1/B3
Playstore & Gapps?
My Honor 7 came with Gapps out of the box, but if you for some reason should loose the Play Store and Gapps after a factory reset, go into the Chinese App Store and search for "Google", find the "Play Store" and install that, search also for Google "Contacts" and install that, after a reboot, you will again have the Play Store and contacts will be able to sync just fine.
Pictures by s7yler
Specifications:
- Mali T624 MP4
- 3100mAh battery
Playstore & Gapps?
Pictures by s7yler
