Help Huawei Mercury Screen Not Responding?? No Water Damage!!
I was texting fine then screen timed out pressed button tried to slide and no response. Removed Bsttery hard reset already and still wont respond. phone was fine no water damage ever and hasnt been dropped! Any ideas pls?? Thanks :)
i know there was an issue with the evo if u got moisture on the screenn the touch response would fail till u reset it but dont know if it couldve been something like that
If you've already tried a hard reset I don't know what else to suggest. Take it to a corporate store and try to get a warranty replacement. Good luck!
i had this happen to me just yesterday .. it seems that the terminals on the battery werent pressing up against the terminals on the phone right.. insert the battery & kinda push the batter up into so that u know for sure that the leads are contacting each other.. i did this & it began working.. put the cover back on & no problems since.. & it actually have after doing a cold restart of my phone.. (pulling battery off while phone is powered)..
