Huawei w1 watch issues
MonoJoker
Hi all
I'm having some issues with my watch and wondering whether there are fixes or if I should cut my losses and get rid of it.
Firstly the connection between my phone and watch seems to have dropped out and will not connect. The android wear app on my Xiaomi Redmi Note 4 says it's connected to the watch but the watch says 'redmi disconnected'. Therefore I can't open the play store on the watch or sync the weather etc.
I tried to connect my Nexus 7 to it but the android wear app on it won't see the watch. The note 7 shows under connectivity but says disconnected and if I click on it and press connect nothing happens.
Also my contacts don't all sync with the watch only some of them.
Any suggestions or is my hardware just not going to work together?
