Help Hudl 2 does not recognise my sd card
spud1962
Having problems with my sd card. The hudl 2 does not recognise it
I have reformatted the card several time using a laptop and panasonic's Sd card formatting software
That card is recognised by my windows laptop via a SD cardreader and I am able to write and read software/files from it.
The "mount SD card" option (insert an SD card for mounting) is greyed out
Any ideas ?
Sounds very similar to me. SD card OK, Hudl behaved as though it was not there. I was convinced I must have damaged the slot contacts or something.
The help forums told me to clear the cache so I did that ... No different
Then I just changed the file manager software. I don't think the problem was actually that but that I had installed the original in KitKat and then upgraded to lollipop which is, I guess when the problem started.
Long story short I installed ES File explorer into Lolipop and I can see onto my SD card again.
This was made in 2015 hehe you should make a new thread describing how you did this now go people need this (well some)
