Yeah I have used tasker for the same thing I don't think it would be the cause.
Open terminal the type the following inside the quote
"su" press enter, give superuser access if it asks
"free"
What does it say?
Mine is:
mem: 610020 582084 27936
Swap: 0 0 0
total: 610020 582084 27936
edit: The forum auto formats so it looks funny
I don't know you could try the updated version of superuser
Did you install any new apps recently?
Also try cleaning your cache.
Hi,
When you say clean cache. Which ones in recovery do you refer to?
Thanks,
Bryan
In recovery just cache not dalvik although it couldn't hurt to clear it
