Huge Problem, app not installing and others
I plugged the usb cable in to my PC and put some songs in my phone.I un-plugged the cable and turned on charging.After some while when I opened the menu in my phone,I saw that some of my apps(Candy Crush,Whatsapp,Viber,Opera,EasyUnrar Lite,CameraZOOM) are gone and some system apps that I disabled after buying my phone (Movie Studio) is restored.
I had backups of those apps via Titanium Backup but when I try to restore them, the apps starts installing and ends up with the message : "App not installed"
NOTE : This is happening only with the apps I mentioned before.I tried installing another new app and its fine. Also my wallpaper,contacts,SD Data are fine.
I'll give anything to get those apps back with data.PLEASE PLEASE
Hmm ..
Sounds like some app files were deleted / over-written / corrupted when you were transfering the music.
I have a suspicion that the only way out of this is to back up your contacts, calendar etc (basically, sync everything you can with Google) and do a Factor Reset .. which is a major PITA, but should allow you to re-install all of your apps.
Hurrah!My problem's solved without FReset. Here's how :
I've downloaded Root Browser and used that to navigate to 'data/user/0' and deleted everything related to the troubling apps and my problem is solved.
