Huge problem with GOkeyboard
jondread
Ok so for some reason, I wake up today, and my GOkeyboard autocorrects the word "im" to "in" instead of "I'm" which is what it used to. This is really frustrating! Can anyone help me please!?
Here's a pic to explain what I mean...
Just press on the "I'm" button it also adds a space so you're pressing the same amount of buttons, you're just not pressing the space bar.
Yes... to my knowledge, that's the way all Android keyboards with auto-correct work. Just press "I'm" next to where the "In" appears in green, and it will remember that choice. You might have accidentally fat-fingered "In" the last time you used it. If you are using the swype feature of the GO keyboard, that's a different issue.
