waterprism
Hi guys,
Need your help, please.
I thought I'd be clever by getting an unlocked HTC Desire S from a Chinese wholesaler through a local middleman. It's really difficult to find this model in South Africa, and so I thought I'm sure the Chinese supplier will do a good job of setting it up for international use -- that's a part of their job, right?
But it's a mess. When I first started it and selected English during setup, it was ok-ish. A bit of Chinese left hanging around here and there, mainly in applications, but not too bad because I didn't use them. But then I had some difficulty getting it to sync with my computer (that old story). And in trying to fix that, the phone froze. I had no choice but to pull out the battery.
Now, since then, I've got all kinds of Chinese things going on! Chinese apps run from the start. There's Chinese stuff in the notification bar. Some Chinese app (I don't even know what app it is) runs just after the start-up screen, taking up the whole screen. I have to press 'home' to get past it. I can't seem to find any way to delete these apps either. And doing a factory reset, since pulling out the battery, doesn't make a difference.
Basically, I just want to get rid of all this Chinese stuff and get the phone to the state it would be if I had bought it from an American or British or South African retailer. How can I do that? It's a disaster like this. Is there some kind of reset or something I can do? I just want the stock United States or United Kingdom HTC Desire S setup, as though I'd bought it from the US or UK instead of these inept idiots I got it from.
Would appreciate your advice. Thanks.
