I had an issue when i flashed the latest Myn's warm twopointtwo RLS5 rom. I had to completely remove hulu and Flash. From that point i reflashed Hulu. Launched Hulu. Clicked on a video. It went to a black or white screen can't remember. Click on the screen and the video should load fine after that. Problem should be solved if you follow those steps. Let me know if that works for you.
