Humid day triggers water mark....
Matthew
So I went golfing the other day and it had been raining and was very humid outside and of course my battery cover came off when I pulled the phone out of my pocket. I grabbed it and put it back on and never thought about it again, the next day however when I was playing with my phone and took the cover off I noticed the water mark had been tripped. No water got on the phone so the humidity must of tripped. Just thought I'd let you guys know because apparently these water marks are super sensitive.
put it in a bowl of rice or put some silicon packets from electronics boxes - I always keep those - around the phone to suck out any moisture.
wait.. you said "the water mark had been tripped" is this some function (screenshot please) or are you saying you got an actual water mark due to humidity & it vanished?
Most mobile phones have several moisture-sensitive strips that react to moisture, so that customer service can see if you got the phone wet, and therefore see that your warranty is voided.
They're usually placed under the battery cover as well, so someone would only have to remove the cover (like the OP) to view the moisture indicator, or expose it to the air for that matter. It should look like a little white dot with red colored plus shaped signs. When wet, the white indicator turns pink or red.
I haven't had a cell phone in the last 10 years or so that didn't get watermarked just from being in my pocket. Both my DROID and my work RAZR are watermarked ... just checked. Oh well...
They are on most smartphones that I've used.
OP was referring to the moisture indicators as "watermarks" (which are something else entirely). Looking at the context of the message helps. ;)
I'm sure someone has found a way to reverse this. Or...replacement indicators. :)
i dont condone this or anything but it works.
my buddy dropped his iPhone in a porta-potty, it was just cleaned so he reached in and grabbed it (pretty nasty...still give him crap about it). obviously it was waterlogged and the waterspots were tripped....he ripped apart the phone, and used bleach to make them all white (obviously this only works with all white indicators), he took it into an apple store, the checked the watermarks, he got a new phone. you could always bleach it, then red ink pen it ;)
and i have heard of these things getting tripped by being in the bathroom when you take a shower. i am sure it will only be in time that mine gets tripped from these Florida summers. i am still good tho :)
I actually thought I might be able to replace the water marks...I'm not sure how but I'm sure it could be done. I also didn't even care that it was tripped because I figured I would never need to replace the phone. This thought of course jinxed me because last night I dropped the phone in the parking lot which put a nice huge crack in the screen... Yeah..
