Help i also need help - settings app missing
bexed111
I have nexus 7 and the settings app is missing and I can't reset it
I also tryed the button reset option where it let's you factory reset it and it says no command any advice ?
If you pull down the Notification bar from the right edge, you should have a shortcut to Settings on the top row.
