I can't move SD supported apps, need help.
Andima
Hi!
I use "Apps2SD" application. So when i try to move apps to SD (supported apps) i receive this error "Fail to move application". error so why is that and how do i fix it.
Thanks!
Hey guys i don't know correct method for fix this issue, but after i factory reset and erase SD card data now everything OK. Fortunately today i received phone from Sony service center so i don't have lot of apps on SD and there is no files on SD so i quickly select factory reset. So in future if again i face this issue i will put in hot water.
I updated this one because of others will helpful.
thanks!
