I con pack/Nova launcher question.
Keizer
I have a Galaxy Note 2 running Nova launcher prime and have installed a half dozen or so icon packs. Everything works great, and I can easily switch between icon packs using Nova launcher.
This morning I discovered how to change the different icons to ones from the pack that I like better. Example: Load the "Boss" icon pack> Long press the icon I want to change>edit>select icon>then pick a new icon from the Boss pack.
This works great until I switch to one of my other icon packs via the Nova launcher. When I switch to say my "Glass" icon pack, any icons that I manually changed while I was using my Boss icon pack remain. They stay Boss, instead of switching to "Glass".
Any way around this? Thanks!
Any icons that you 'manually' change have to be just that, manually changed. If you switch icons packs then the icons that you choose yourself will remain the same until you 'manually' change them again to whatever icon pack you want to use.
Okay, thanks for the explanation! I appreciate it.
