I-Digit Watch Face
May 22, 2015
67
114
Hi,
I released a new watch face: I-Digit Watch Face
https://play.google.com/store/apps/details?id=fr.thema.wear.watch.idigit
As always, free to try, but if you like the design, you can unlock all the features as a premium user.
The free version has a lot of settings to customize your watch face: colors, date, format, etc...
The premium unlocks the custom data, complications, custom shortcuts, secondary timezone, and a lot more!
I hope that you will like it!
I would like to install your app on my Sony Smartwatch 3, but it tells me I have to instll Google Play Store on my watch. I can't find it on my watch and it should be there by default. Suggestions? I have Android 10 on my phone, Android 6.0.1 and Android Wear 1.5.0.35 on my watch.
It's been a couple years since I used a Wear watch, but if I remember right, you need to open play on the watch and agree to the TOS for it to work. See this for help:
https://support.google.com/googleplay/answer/7314788?hl=en-GB
Upvote 0
Android Wear 1.x doesn't include an on-watch Play Store, and unfortunately it's not really supported by the way wearable apps (and watch faces) are required to be packaged now.
  • Like
Reactions: Unforgiven
Upvote 0
Your watch is running the old Wear OS 1.x
The watch embedded part of the watch face is pushed automatically by the Wear OS system to the watch.
But if for some reason it did not, here are a few steps you can try to enforce the installation process:
1) You can try to reboot both devices to clear the bluetooth wear os stack. Then try to open the Wear OS app settings and use Re-sync apps option.
Then wait a few minutes.
2) If not working : uninstall the watch face from your mobile, wait a few minutes, restart both watch & mobile, then finally install the watchface.
3) Lastly, if none of the previous solutions worked, please disconnect devices(watch and phone), uninstall the watch face, restart watch and connect device again. then finally install the watchface.
Upvote 0
I wouldn’t say I like such models. As for me, those are outdated. I only divide watches into two categories; the useful electronical ones and pretty. I use good watches at the gym to see how many calories I have burned, what was my heartbeat, and other helpful information. While, I use pretty ones to go to the office, for meetings, celebrations and going out. I buy the last category in luxurious brands and pay thousands for them. I put them in a pretty watch winder too. And that watch you posted is somewhere in the middle; pretty useless
Upvote 0
BEST TECH IN 2023
Smartphones
