Root I factory reset my rooted L22C . . . Help
mikey79
So, after the reset the phone has gone nuts. Only the back button works of the soft-keys, I don't get notifications normally, every time it reboots it goes back through the setup process again but remembers the previous answers.
Any ideas? I can't find a factory image to flash it with. My wife also has one of these phones, could it be possible to clone hers?
Hi,
I have an unmodified l22c. If I can help somehow (like make a factory image) let me know. I am curious how you rooted your l22c. You are the first person to say they rooted their l22c. Did you delete McAfee? Isn't bloatware fun?
I can't get it to connect to the lg support tool right now, this model isnt listed with the drivers it installs, so i really dont know what to do at this point
The same thing happened to me, actually. I rooted using kingroot, I think there are instructions in the Lg Leon (similar phone) forums here or on xda or Android central. I deleted a bunch of bloatware including McAffee but then I did a factory reset, and the phone had the same problems as yours. I decided to get a new one because there was no way to fix it.
