Help i got it! one problem......
gabbyevs
the headphones are different nothing else works in the plug so means my tape adaptor wont work in my car
anyone know if they do new style ones now?
thats the one i have but sony have jut told me online i need an adaptor and for the life of me i cant find one in the uk
i must double check it then maybe mine isnt the same
if it doesnt work have ytou any idea where i can get the ec250 adaptor?
You have a problem there Gabby, any chance you can just upgrade your car stereo? Do you drive a classic?
i cant afford a new stereo jase
they might be right angelus im going to check my car adaptor first then see
thanks both for your help
dont know why they had to make things different but then maybe all headphones will be this type soon
